domiky Posted February 11, 2016 Posted February 11, 2016 It's under Topic View settings. What does it do? "Separated" topic layout? Thanks.
Solution Ehren Posted February 11, 2016 Solution Posted February 11, 2016 You should generally keep that as-is since certain themes are designed based around it.. But it slightly changes the layout of the topic by placing a gap between posts, as the name suggests 1
