loz Posted September 6, 2011 Posted September 6, 2011 No new template bits were added, just a new replacement. But there was a considerable amount of changes which were made between 3.2.1 and 3.2.2 Ehren is there chance to know what that replacement is, all the changes applied but just missing that replacement to add? I will do it differently on the next update of the skin, adding changes I made instead of other way round, but for now, I want to get that skin perfect on 3.2.2.
Ehren Posted September 7, 2011 Author Posted September 7, 2011 A replacement was just added for the copyright. If the "Skin by ipbforumskins" link exists, you don't need to add anything.
loz Posted September 7, 2011 Posted September 7, 2011 ah ok, thanks mate, it exists there fine so will carry on as usual. Thanks for all your help.
bikeside Posted September 21, 2011 Posted September 21, 2011 When will be the "Navia" skin updated to v3.2.x?
Ehren Posted September 21, 2011 Author Posted September 21, 2011 I have one new skin in production which is about 80% complete, and Navia should come after that. 1
Kanade Posted September 21, 2011 Posted September 21, 2011 Looking forward to both the new skin and Navia
nodle Posted September 21, 2011 Posted September 21, 2011 I have one new skin in production which is about 80% complete, and Navia should come after that. Oh boy getting excited!
nodle Posted September 29, 2011 Posted September 29, 2011 I really liked what you have done with the last two skins, Marble and Navia. The new features are nice. On the next remakes of your skins you should add these options in. Keep up the great work Ehren!
Ehren Posted September 30, 2011 Author Posted September 30, 2011 Yep - the 'settings' template file will be gradually included to work with the current 3.2 skins
