Square Wheels Posted October 14, 2026 at 09:02 PM Posted October 14, 2026 at 09:02 PM Oopsie, I updated to the beta by mistake; I meant to update to 5.0.20. Any theme changes that will be needed?
Ehren Posted October 14, 2026 at 09:35 PM Posted October 14, 2026 at 09:35 PM Not that I'm aware of. These themes have been designed to ensure they're compatible with as many versions as possible. You should be all good! 1
Square Wheels Posted October 15, 2026 at 03:00 PM Author Posted October 15, 2026 at 03:00 PM One user said he does not see notifications on his iPhone. I don't have any i devices, so I cannot confirm this.
Square Wheels Posted October 15, 2026 at 03:57 PM Author Posted October 15, 2026 at 03:57 PM More followup So my iPhone is set to the non-ISP default theme. I just saw a pop-up on screen on my PC that said KZOO had responded to something I posted yet no red number one on either my PC or iPhone. Here are two screenshots from my iPhone. The first one shows no red number one next to the notification. The second one shows when I open notifications that kzoo responded one minute ago.
Square Wheels Posted October 15, 2026 at 04:32 PM Author Posted October 15, 2026 at 04:32 PM Maybe easier to post a link to the posts here? https://squarewheelscycling.com/topic/219972-updates/
Ehren Posted October 17, 2026 at 02:26 AM Posted October 17, 2026 at 02:26 AM Uniform doesn't modify the functionality of the notifications bubble. But if you believe the notifications aren't behaving correctly, you can post it as a bug on the Invision site and it'll be investigated further 1
